Snakes1000
Message 1 of 29
Help Req'd - BB Connection Keeps Dropping Since Fitting Accelerator Plate - Helpline cannot resolve
It's a long story so here's the short version.  Any guidance or advice would really be appreciated!
Very long-term BT customer
On Broadband Option 3 tariff
Have BT Vision Package
Router is version 1.5
Wireless connection to PC
1 main socket and two further sockets in house
Broadband connection has been solid until accelerator plate fitted
Drop outs for first few days as advised and anticipated
Solid thereafter but after a few weeks drop outs returned
Faults first reported 29 May to BT helpline and several times since but still not resolved
Connection initially OK (i.e. for several days) when using test socket
But now fails even when in clean socket state
Connection drop-outs can be once every 24 hours to once every hour
All phone connections clear
I have tried an old router
I have tried a replacement filter
Phone light (fourth from left) sometimes not illuminated
Status Info:-
Product Name:                    BT Home Hub 15
Serial Number:                    CP0743EH3Z4
Software Release:                6.2.6.H
Software Variant:                BP
Boot Loader Version:           2.0.7
Product Code:                     36308970
Board Name:                       BANT-Z
Tried btspeedtester
Max download speed was 8.1 mbps but then estimated speed was 4.6 (IP profile?)
Could anyone please advise what I should do next?
Thanks in advance
28 REPLIES 28
Message 2 of 29
Re: Help Req'd - BB Connection Keeps Dropping Since Fitting Accelerator Plate - Helpline cannot reso
Hi Welcome to the forums  Your IP Profile is low because of disconnections that will rise automatically once you can maintain 3days + stable connection with no restarts
Here are some help pages done by CL Keith http://forumhelp.dyndns.org/speed/Speed.html
also post your full hub stats by entering 192.168.1.254 into your web browser address bar and navigate to adsl or use a-z, if netgear enter 192.168.0.1
Can you also post the full results from BT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket  Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
Snakes1000
Message 3 of 29
I thought I had provided stats and speedtest results
Message 4 of 29
hi there is no hub stats sorry just spotted the speed test
we need to se the results of the full BT Speedtest
and the hub stats showing connection time
speed
noise margin
attenuation
and errors
Message 5 of 29
the first link i posted shows a link to the adsl stats they are the results we are looking for
Snakes1000
Message 6 of 29
OK, I am trying to get the info you have asked for!
I have enteredt 192.168.1.254 into my web browser.
The menus are:-
Home
Telephones
Basic Config
Services
Troubleshooting
Advanced
I chose advanced and navigated to ADSL and got this-
DSL Connection
Link Information
Uptime:                               0 days, 2:30:05
Modulation:                          G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:         448 / 8,064
Data Transferred (Sent/Received) [MB/MB]:         13.28 / 138.22
Snakes1000
Message 7 of 29
the advanced menus are;-
Wireless
Telephony
Internet
IP Addresses
Devices
Application Sharing
Firewall
Dynamic DNS
System
Status
Can you direct me from here?
Message 8 of 29
check out all options please
you should should see a page like is shown for the stats for the home hub 1
http://www.btinternet.com/~cbeddoe/forumhelp/speed/adslstats.html
Snakes1000
Message 9 of 29
OK, I think this  is it-
DSL Connection
Link Information
Uptime:                                                 0 days, 3:26:55
Data Transferred (Sent/Received):          23.50 / 347.03
Output Power (Up/Down) [dBm]:             11.0 / 19.5
Line Attenuation (Up/Down) [dB]:            21.0 / 40.0
SN Margin (Up/Down) [dB]:                     28.0 / 10.0
Vendor ID (Local/Remote):                      TMMB / IFTN
Loss of Framing (Local/Remote):             0 / 0
Loss of Signal (Local/Remote):                0 / 0
Loss of Power (Local/Remote):                0 / 0
Loss of Link (Remote):                            0
Error Seconds (Local/Remote):                10 / 0
FEC Errors (Up/Down):                            0 / 41,868
CRC Errors (Up/Down):                           0 / 893
HEC Errors (Up/Down):                           0 / 744
Line Profile:                                            Interleaved
Message 10 of 29
are the stats from connection to test socket?  I know you use accelerator but have you disconnected the bellwire on terminal 3 in all your sockets
bellwire removal
there is nothing obvious from the router stats you have posted
