Message 21 of 32
Re: Help! Very slow connection since last week and no improvement ....
Still in the test socket.  These are today's results ......
This Test comprises of Best Effort Test:  -provides background information.
 Download Speed
 55 Kbps
0 Kbps 250 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 55 Kbps
 For your connection, the acceptable range of speedsis 100-250 Kbps.
 IP Profile for your line is - 135 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 11.72:32.75:55.98 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
Note: An Upstream test was not conducted on this line due to a technical issue. If your concern is related to upstream performance then please retry
the performance test again in 1 hours time.
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 2:15:34
Downstream 2,656 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Interleaved
Noise margin (Down/Up) 14.3 dB / 18.0 dB
Line attenuation (Down/Up) 51.0 dB / 31.5 dB
Output power (Down/Up) 17.8 dBm / 12.6 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 13282 / 23
CRC Errors (Down/Up) 501 / 2147480000
HEC Errors (Down/Up) nil / 13
Error Seconds (Local) 16
This is day 3 now and there's not much improvement at all.  Any ideas?
Thanks in advance
Amanda
Tags (1)
Message 22 of 32
re-reading your previous posts you mention noise on your line during phone calls - if you do the quiet line test - dial 17070 option 2 - is it quiet or is there noise/crackle - best done with a corded phone if possible.
just in the test socket you are still dropping connection and noise margin not coming down
if you hear noise then report a phone fault NOT a broadband fault - dial 151
Message 23 of 32
Thanks.  I've done the quiet test on a corded phone in the test socket and there is still noise and crackle although not quite as bad as before.  I will report the fault on the phone line and see what happens.
Thanks for your advice.
Kind regards, Amanda
Message 24 of 32
any noise/crackle on your line is a killer for your broadband so hopefully if phone engineer fixes crackle should help the broadband
Message 25 of 32
Okay thanks for your help.  I will report the fault now and see what happens.
Fingers crossed .....
Kind regards,
Amanda
Message 26 of 32
Well I can't fault BT so far!  I rang them at about 10.20pm last night, reported the fault and at 8.10am this morning, two engineers turned up and have now replaced the external cabling so there is no noise at the master socket.  Hooray!
Here are the test results which I have just run:
 Download Speed
 64 Kbps
0 Kbps 250 Kbps
 Download speedachieved during the test was - 64 Kbps
 Additional Information:
 Your DSL Connection Rate :2592 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
The throughput of Best Efforts (BE) classes achieved during the test is - 28.13:17.31:54.78 (SBE:NBE:PBE)
2. Upstream Test:  -provides background information.
 Upload Speed
 342 Kbps
0 Kbps 448 Kbps
>Upload speed achieved during the test was - 342 Kbps
 Upstream Rate IP profile on your line is - 448 Kbps
ADSL line status
Connection time 0 days, 0:10:10
Downstream 2,592 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 15.1 dB / 17.0 dB
Line attenuation (Down/Up) 52.0 dB / 31.5 dB
Output power (Down/Up) 17.7 dBm / 12.6 dBm
FEC Errors (Down/Up) 51 / 0
CRC Errors (Down/Up) 0 / 2147480000
HEC Errors (Down/Up) nil / 0
Error Seconds (Local) 0
I would hope that the results will improve over the next 3/5 days?
Thanks for your help,
Amanda
Message 27 of 32
Hi Amanda
that looks far better and well worth the phone call.  now just need to wait until your rock bottom profile of 135 catches up with your need speed
Message 28 of 32
Great, that's just what I wanted to hear!  I'm so glad it all makes sense to you as it doesn't mean much to me!!
Will keep you posted but as ever, thank you so much for your help.
Kind regards,
Amanda
Tags (4)
Message 29 of 32
your noise margin is still a bit high so just stay connected 24/7 and that will drop with an increase in your speed.  With all the changes down by the engineers your line could have gone back into training so just reamin connected
Message 30 of 32
Hi there - one very happy bunny here!  Things are much more stable and faster.  We are now back in the master socket and no loss of connection again.
Here are today's test results:
1. Best Effort Test: -provides background information.
Download Speed
1904 Kbps
0 Kbps2000 Kbps
 Download speedachieved during the test was - 1904 Kbps
 For your connection, the acceptable range of speedsis 800-2000 Kbps.
 IP Profile for your line is - 2000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.99:20.57:65.47 (SBE:NBE:PBE)
Upload Speed
347 Kbps
0 Kbps448 Kbps
>Upload speed achieved during the test was - 347 Kbps
Line stateConnected
Connection time2 days, 3:41:03
Downstream2,592 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)14.7 dB / 18.0 dB
Line attenuation (Down/Up)52.0 dB / 31.5 dB
Output power (Down/Up)17.9 dBm / 12.7 dBm
Loss of Framing (Local)11
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)21788 / 163
CRC Errors (Down/Up)265 / 2147480000
HEC Errors (Down/Up)nil / 120
Error Seconds (Local)163
Do let me know if you see anything else in the results that I should know about (!) otherwise thanks so much for your invaluable help Smiley Happy
Kind regards,
Amanda
