ImranKhan1
Message 1 of 3
Help me understand this wiring
First time posting, just bought this property and there is this unsightly wiring sticking out of the wall in the bedroom. There is a BT logo on the white box pictured above.
I have a bt phone line box in the other corner of this room.
It looks like this black wire is the telephone line coming into the room from
outside the property and that white wire converts that into a telephone wire for the connection in this room?
what can i do about it?
thanks in advance
2 REPLIES 2
licquorice
Message 2 of 3
Re: Help me understand this wiring
Other than fixing the box to the wall and shortening and re-connecting the wires to tidy it up, not a lot.
Devon_Dave
Distinguished Guru
Message 3 of 3
You could purchase a larger plastic box from tools*ation or screwf*x and hide all wiring a connecting box inside.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
