Message 11 of 14
Re: Help moving from ADSL MAX to ADSL2+ and enabling fast path
Hi Again,
Everything looks good:
DSL Status:UP
DSL Modulation Mode:G.992.5 (ADSL2+)
DSL Path Mode:FAST
Downstream Rate:3802 Kbps
Upstream Rate:816 Kbps
Downstream Margin:6 db
Upstream Margin:6 db
Downstream Line Attenuation:58
Upstream Line Attenuation:67
Downstream Transmit Power:21
Upstream Transmit Power:12
LOS Errors:0
Thanks!
Will the line be retrainded again over the next 10 days?
Message 12 of 14
I would try and avoid any resets apart from hub resetting itself as it settles
down speed much the same as and big increase in upstream - as expected
looking good
Message 13 of 14
Had to turn the mains off to install an EV point:
DSL Status:UP
DSL Path Mode:FAST
Downstream Rate:3583 Kbps
Upstream Rate:848 Kbps
Upstream Margin:5 db
Downstream Line Attenuation:60
LOS Errors:0
Will the training over the next 10days recover the downstream loss?
Message 14 of 14
you just have to wait and see   when you need to disconnect the hub it is better to do it from the hub manager and disconnect from there rather than just switch off
