Hi Again,
Everything looks good:
DSL Status: | UP |
DSL Modulation Mode: | G.992.5 (ADSL2+) |
DSL Path Mode: | FAST |
Downstream Rate: | 3802 Kbps |
Upstream Rate: | 816 Kbps |
Downstream Margin: | 6 db |
Upstream Margin: | 6 db |
Downstream Line Attenuation: | 58 |
Upstream Line Attenuation: | 67 |
Downstream Transmit Power: | 21 |
Upstream Transmit Power: | 12 |
LOS Errors: | 0 |
Thanks!
Will the line be retrainded again over the next 10 days?
I would try and avoid any resets apart from hub resetting itself as it settles
down speed much the same as and big increase in upstream - as expected
looking good
Had to turn the mains off to install an EV point:
DSL Status: | UP |
Downstream Rate: | 3583 Kbps |
Upstream Rate: | 848 Kbps |
Upstream Margin: | 5 db |
Downstream Line Attenuation: | 60 |
LOS Errors: | 0 |
Will the training over the next 10days recover the downstream loss?
you just have to wait and see when you need to disconnect the hub it is better to do it from the hub manager and disconnect from there rather than just switch off
