Message 1 of 14
Help moving from ADSL MAX to ADSL2+ and enabling fast path
Hi,
I'd like to move to ADSL2+ and enable fast path on my line. Is this possible?
My line stats are:
DSL Modulation Mode:G.992.1 (G.DMT)
DSL Path Mode:INTERLEAVED
Downstream Rate:3968 Kbps
Upstream Rate:448 Kbps
Downstream Margin:6 db
Upstream Margin:17 db
Downstream Line Attenuation:60
Upstream Line Attenuation:63
Downstream Transmit Power:3
Upstream Transmit Power:12
LOS Errors:0
I see my exchange is ADSL2+ enabled:
Many thanks in advance.
13 REPLIES 13
Message 2 of 14
Re: Help moving from ADSL MAX to ADSL2+ and enabling fast path
Welcome to this user forum.
At your distance from the exchange, you would be very unlikely to see any improvement in the download speed, but you may see an improvement in the upload speed.
Changing to fastpath from interleaved, may result in more line errors and possibly slower throughput.
Regrading to ADSL2+ would also mean starting a new contract. Do you still want to request the change?
Message 3 of 14
Thanks for the reply.
I've just started this contract but happy to upgrade if that is necessary to improve upload. I assumed that I'd be on ADSL2+ and didn't see any other option when signing up.
I'm happy to sacrafice line speed and stability for improved latency.
Message 4 of 14
the mods will try and get you upgraded to adsl2  they will post here
adls2+ is only effected if your down speed is 11mb+  so adsl2 will give you same speed down and up
Message 5 of 14
Perfect, look forward to hearing from them 🙂
Moderator
Moderator
Message 6 of 14
Hi @iamdjango,
If you send me in your details, I'll be able to upgrade to to ADSL2 if possible. You can send me in your details by clicking on the "Contact The Mods" link found in the "about me" section of my profile.
PaddyB
Message 7 of 14
I've filled in form:
Many thanks.
Tags (1)
Moderator
Moderator
Message 8 of 14
Hi @iamdjango,
Thank you for confirming. One of the team will be in touch as soon as that reaches the top of the queue.
PaddyB
Moderator
Moderator
Message 9 of 14
@iamdjango I tried calling there but couldn't reach you, I've made a request with BT Wholesale to get you over to ADSL2+ which will complete in the next 24 hours. Can you post back to let me know when you see that it's changed?
Message 10 of 14
Hi Neil,
Sorry I missed your call, my other half was vacuuming 😕
Sure I'll post back.
Many Thanks.
