johnjazz
Message 1 of 2
Help needed to connect Archos G90 to BT HHv2
Aa a newbie here I hope this is the right place to post.  I've recently got an Archos G90 tablet.  It tells me it's connected to my home hub but fails to connect with the internet.  Same with BTFON.  In fact I'm still stuck with limited/access problem when I try to connect to FON on my laptop.  After trying to connect with the Archos I have turn the device off and then restart the hub to restore its settings .  I've also reset the hub but there was no change. As far as I can tell my hub settings are okay and it has the latest firmware.
So mainly I need to get the tablet connected reliably and without upsetting the hub settings.
Secondly if there is a link to a cure for the limited/local access problem with my home BTFON I'd be delighted to know.
Internet access via the hub is generally reliable on both my laptop and PC, both connected wirelessly.  I have BT Infinity and Vista OS.
1 REPLY 1
DavidM
Moderator
Moderator
Message 2 of 2
Re: Help needed to connect Archos G90 to BT HHv2
Hi Johnjazz,
Thanks for posting. I've had a look around and found this which might help. Let me know if it does.
Cheers
David
