Message 1 of 5
Help on download Speeds
Could any one answer the following whether this is a acceptable speed or is it slow
Home Image not loadedTesting Image not loadedResult Image not loaded
FAQ
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
10599 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 10599 Kbps
 For your connection, the acceptable range of speedsis 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :18482 Kbps(DOWN-STREAM), 1181 Kbps(UP-STREAM)
 IP Profile for your line is - 15000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 8.05:18.94:73.02 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
480 Kbps
0 Kbps1181 Kbps
>Upload speed achieved during the test was - 480 Kbps
 Upstream Rate IP profile on your line is - 1181 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit FAQ section if you are unable To understand the test results.
Notes:
The Download Speed is the average rate that was achieved during this test.
Notes:
Your line is configured to the maximum rate that it can support or at your chosen fixed rate, this is known as the line rate and would be viewed through your CPE software or in your router configuration.
Your IP profile is always less than the line rate and is normal on any network.
The Upstream Test rate figure quoted will always be smaller than the assured rate profile. This is because in order for the throughput to reach its destination, it requires an overhead which explains the difference between the two.
Notes:
If your download speed lies in this range then your connection seems to be working fine.
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
4 REPLIES 4
Message 2 of 5
Re: Help on download Speeds
Also forgot to add this is a new line which has been active for two weeks was told my line could handle 17mb download speed
Message 3 of 5
<script type="text/javascript"></script>
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 08:10:42
Downstream:18.05 Mbps
Upstream:1.154 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):5.7 dB / 6.2 dB
Line attenuation (Down/Up):19.4 dB / 10.7 dB
Output power (Down/Up):20.1 dBm / 12.4 dBm
FEC Events (Down/Up):69655 / 412
CRC Events (Down/Up):65 / 41
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):970 / 8
Error Seconds (Local/Remote):129 / 1
Software version 4.7.5.1.83.8.57 (Type A) | Time and date 15:42 19/03/11
Message 4 of 5
you have an 18mb connection and your stats look ok.  The download speed could be down due to congestion with the number of people using the net on your exchange.
check your exchange for problems  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
Message 5 of 5
Hi you have an 18.5mb connection currently your ip profile is a little low at 15000k it should be 16000k and your throughput is currently at the test you ran 10.6mb which will vary constantly depending on network loading and internet activity in general left alone your ip profile should rise to its 16000k setting but at this stage you have a very good connection and good throughput that will vary on time of day and all the other variables certainly nothing to worry about
