Message 1 of 3
Help please asap?
My tp link 9980 3rd light from left not been on now for 2 days tp link saying it's bt fault a PPP server failed and to double check with BT if there not changed there 3rd party router settings.
What are the current tp link router settings username, password, vci, vlan.
Please thank u
Thank you
2 REPLIES 2
Message 2 of 3
Re: Help please asap?
Hi,
There should be a quick setup within the routers menu...
Enable VLAN ID: Tick
VLAN ID: 101
PPPoE(PPP over Ethernet)
PPPoE Username is: bthomehub@btbroadband.com
Password: [blank] or [bthomehub@btbroadband.com]
Message 3 of 3
Thank u
