hello...my hub is dead so i decide to buy a netgerar n300 wireless modem router , but i need help to setup it,because is already 2 hour but i can not get access to internet. Any helps?
Go into the router settings and enter the username bthomehub@btbroadband.com You don't need a password but if your router needs one you can use any password you want.
EDIT: Do you have "normal" broadband or Infinity fibre broadband?
If you are on infinity then the n300 is adsl modem so will only work on infinity with a separate modem
