old_email
Message 1 of 1
Help understanding Home Hub 4 Firewall logs
Just wondering what is getting through from the outside and these are some logs of the past few minutes - not sure what some of them mean.  How can I be sure nothing is getting through that shouldn't?  What are the likely sources of IN: ACCEPT and what is the blocked Remote Administration?  Thanks.
Time and date Message
12:26:58, 05 Jun.IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.66:50782 <-->86.138.56.164:50782 [125.166.237.56:23026] ppp0 NAPT)
12:24:37, 05 Jun.BLOCKED 4 more packets (because of Packet invalid in connection)
12:24:36, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 173.194.34.87:443->86.138.56.164:4723 on ppp0)
12:24:09, 05 Jun.IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.66:50782 <-->86.138.56.164:50782 [125.166.237.56:23026] ppp0 NAPT)
12:22:05, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 199.30.80.32:80->86.138.56.164:4754 on ppp0)
12:22:05, 05 Jun.BLOCKED 2 more packets (because of Packet invalid in connection)
12:22:05, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 199.30.80.32:80->86.138.56.164:4745 on ppp0)
12:22:01, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 213.120.163.207:80->86.138.56.164:4751 on ppp0)
12:21:45, 05 Jun.BLOCKED 1 more packets (because of Packet invalid in connection)
12:21:44, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 199.30.80.32:80->86.138.56.164:4711 on ppp0)
12:21:40, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 95.100.194.110:443->86.138.56.164:4715 on ppp0)
12:21:40, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 92.122.123.67:80->86.138.56.164:4700 on ppp0)
12:21:36, 05 Jun.BLOCKED 1 more packets (because of Packet invalid in connection)
12:21:35, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 173.194.34.87:443->86.138.56.164:4667 on ppp0)
12:19:55, 05 Jun.BLOCKED 1 more packets (because of Packet invalid in connection)
12:19:55, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 173.194.34.87:443->86.138.56.164:4632 on ppp0)
12:18:44, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 199.30.80.32:80->86.138.56.164:4665 on ppp0)
12:18:43, 05 Jun.IN: BLOCK [9] Packet invalid in connection (TCP 199.30.80.32:80->86.138.56.164:4660 on ppp0)
12:17:22, 05 Jun.IN: BLOCK [16] Remote administration (TCP 31.6.71.135:44428->86.138.56.164:8080 on ppp0)
12:17:15, 05 Jun.IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.66:50782 <-->86.138.56.164:50782 [39.253.88.33:23489] ppp0 NAPT)
