Message 1 of 11
Help understanding something please.
I edited out my IP address. What does all this mean. The IP address is from China.
02:52:01, 12 Oct. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=221.192.199.50 DST=IP LEN=40 TOS=0x00 PREC=0x00 TTL=108 ID=256 PROTO=TCP SPT=39441 DPT=8000 WINDOW=512 RES=0x00 SYN UR
02:52:01, 12 Oct. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=221.192.199.50 DST=IP LEN=40 TOS=0x00 PREC=0x00 TTL=108 ID=256 PROTO=TCP SPT=39441 DPT=1337 WINDOW=512 RES=0x00 SYN URGP=0 MARK=0x8000000
02:52:01, 12 Oct. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=221.192.199.50 DST=IP LEN=40 TOS=0x00 PREC=0x00 TTL=108 ID=256 PROTO=TCP SPT=39441 DPT=9999 WINDOW=512 RES=0x00 SYN URGP=0 MARK=0x8000000
02:52:01, 12 Oct. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=221.192.199.50 DST=IP LEN=40 TOS=0x00 PREC=0x00 TTL=109 ID=256 PROTO=TCP SPT=39441 DPT=808 WINDOW=512 RES=0x00 SYN URGP=0 MARK=0x8000000
02:52:01, 12 Oct. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=221.192.199.50 DST=IP LEN=40 TOS=0x00 PREC=0x00 TTL=109 ID=256 PROTO=TCP SPT=39441 DPT=3130 WINDOW=512 RES=0x
02:52:01, 12 Oct. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=221.192.199.50 DST=IP LEN=40 TOS=0x00 PREC=0x00 TTL=109 ID=256 PROTO=TCP SPT=39441 DPT=63000 WINDOW=512 RES=0x00 SYN URGP=0 MARK=0x8000000
02:52:01, 12 Oct. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=221.192.199.50 DST=IP LEN=40 TOS=0x00 PREC=0x00 TTL=109 ID=256 PROTO=TCP SPT=39441 DPT=8085 WINDOW=512 RES=0x00 SYN URGP=0 MARK=0x8000000
10 REPLIES 10
Message 2 of 11
Re: Help understanding something please.
It means your firewall is doing its job.
Message 3 of 11
Also my IP is listed on a spam site, on multiple spam sites? whats going on with that.
Message 4 of 11
that can happen  just reset your router and you should get a different ip address - probably unplug wait a few minutes and then reconnect
Message 5 of 11
Thank you for your kind responses imjolly and Liquoirice, Just a final question. I do know that it's my firewall doing its job but it's come across as a port scan, usually it registers as a DoS(Updolock) or something along those lines.
Does anything seem out of the ordinary with this, the IP seems to be coming from China
Message 6 of 11
as alreday said it is your firewall doing it's job and protecting router and you
Distinguished Guru
Message 7 of 11
If you connect anything to the internet, then it will get scanned constantly.  That's perfectly normal, and has been going on for years.
It will be a mixture of nosy automated systems scanning the internet just to see what's out there, and viruses looking for new machines to infect.  The Hub's firewall blocks all of them unless you specifically open ports.
Message 8 of 11
I see thanks that makes a bit more sense. Another message that seemed to crop up is this?
Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports:
along with a set of rules and a external port use from an IP address belonging to an IPAD my family member possess. Any idea what this is. Sorry for bothering again
Distinguished Guru
Message 9 of 11
Most likely an app (probably a game) wants to establish communication with a server.
Normally, the Hub firewall will block all incoming packets unless they are responses to previous requests.  But this doesn't work well with some applications where the server needs to send updates from time to time, or systems that use peer-to-peer networking.
UPnP (Universal Plug & Play) is a system where devices on the home network can ask the router (the Hub in this case) to open specific ports and route any incoming messages on that port to that device.
Message 10 of 11
I see thank you for the information. she was trying to do a skype call with a friend at the time, would that have caused it?
