Den
Message 1 of 6
Help, using desktop help but getting this message "The cache in your browser can not be cleared"
 I am using the PC health check and getting this message - the cache in your browser can not be cleared.  What do I need to do to clear it?
5 REPLIES 5
Message 2 of 6
Re: Help, using desktop help but getting this message "The cache in your browser can not be cle
If you are using Internet Explorer click on the circled option.
Message 3 of 6
you could try this link www.wikihow.com/Clear-Your-Browser's-Cache
you do not need desk top help as many posters here will tell you
Den
Message 4 of 6
Thanks!
Den
Message 5 of 6
Thanks!
DarrenB
Message 6 of 6
Hi,
Just to clarify, the automated fix within desktop help is unable to clear your cache?
Can you tell me what version of IE and OS you are using.
Kind Regards
Darren
