kittyk192
Message 1 of 11
Help very sudden drop in speed
Hello as of 2 days ago i have had a rather sudden lack of speed, until this problem occured i was able to download @ 900Kb/s on a good day nearly 1meg/s but now i cant even run btspeedchecker as it crashes.
I have tried the following:
1) connected straight to master socket (inside cover)
2) different extension cord
3) no extension cord
4) new filter
5) Complete reinstall of OS.
6) Turned off wireless on router incase of unauthorised access eating bandwidth
7) disabled firewall
still no joy please help
katrina
speedtest.net comes up as follows:
Info From Hub:
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:26:13
Downstream9,586 Kbps
Upstream1,164 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)3.1 dB / 4.8 dB
Line attenuation (Down/Up)41.5 dB / 18.9 dB
Output power (Down/Up)0.0 dBm / 12.9 dBm
Loss of Framing (Local)23
Loss of Signal (Local)3
Loss of Power (Local)0
FEC Errors (Down/Up)1049542 / 4294967148
CRC Errors (Down/Up)15 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)
19
Tags (4)
10 REPLIES 10
kittyk192
Message 2 of 11
Re: Help very sudden drop in speed
UPDATE:i have now managed to get the btspeedchecker to complete a check and the info is as follows:
1. Best Effort Test: -provides background information.
Download Speed
74 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 74 Kbps
 For your connection, the acceptable range of speedsis 2000-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :9586 Kbps(DOWN-STREAM), 1164 Kbps(UP-STREAM)
 IP Profile for your line is - 6500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.47:29.67:51.86 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
921 Kbps
0 Kbps1164 Kbps
>Upload speed achieved during the test was - 921 Kbps
 Upstream Rate IP profile on your line is - 1164 Kbps
Tags (4)
zoiX
Newbie
Message 3 of 11
Having exactly the same problem, we've changed nothing at all on our end, but about 2 days ago the speed of our line just totally died. Even when we've checked it at off-peak times, the speed of the line is a total joke - at least when dial-up existed webpages were almost exclusively html!!
kittyk192
Message 4 of 11
Bump can anyone helpppppppppp!!!!!
Tags (3)
Geoff93
Recognised Expert
Message 5 of 11
Given that your IP profile is good but your throughput is rubbish I would email mod for assistance giving account and phone number and link back to this thread. forum.moderation.team@bt.com
tally2425
Message 6 of 11
I can join that club, Was getting around 5mb, Now im dropping to around 1mb or less i have a post up aswell. Ive rang BT so many many times and nothing has happend, i was getting around 5mb for 11 months now getting less than 1mb.
kittyk192
Message 7 of 11
Bump
Moderator-Retired
Message 8 of 11
Hi kittyk192,
Did you send us an email as Geoff93 suggested?
We'll need your BT account and telephone number along with a link back to this thread.
Just send to the email address in my profile and mark FAO Craig please.
Thx
Craig
BTCare Community Mod
If we have asked you to email us with your details, please make sure you are logged in to the forum, otherwise you will not be able to see our ‘Contact Us’ link within our profiles.
We are sorry but we are unable to deal with service/account queries via the private message(PM) function so please don't PM your account info, we need to deal with this via our email account :-)”
td-p/30">Ratings star on the left-hand side of the post.
kittyk192
Message 9 of 11
Hello i have emailed as suggested however i shall send email again marking FAO Craig. also the last part of the speed checker (where you have to change username) does not work for me.
katrina
**Update email sent marked FAO Craig thanks
rng
Message 10 of 11
welcome to the club 🙂
exaclty same
http://community.bt.com/t5/BB-in-Home/is-it-a-good-idea-to-turn-off-interleaving/td-p/72109
Download Speed 280 Kbps
with
Line state      Connected
Downstream      10,294 Kbps
Upstream        1,169 Kbps
my exchange is WRBRIX (Brixton, London)
you can check your exchange here:
http://usertools.plus.net/exchanges/
