everyday
Message 1 of 11
Help with ringing UK from USA
I have just loaded Smart Talk onto our mobile as we are going to the USA shortly. If we want to ring a UK number from the USA using Smart Talk, do we just dial the UK local number or do we still use the international dialling code (0044)? If the latter, do we need to remove the International call bar first?
10 REPLIES 10
Incognito
Message 2 of 11
Re: Help with ringing UK from USA
you just dial as if you are at home so no international codes required.
everyday
Message 3 of 11
Thanks for the reply - have you tried doing that when abroad?
ray_dorset
Distinguished Guru
Message 4 of 11
Both should work.
If not, I'll try again 🙂
pottyperson
Distinguished Guru
Distinguished Guru
Message 5 of 11
Just called my daughter from Copenhagen simply using her contact details already stored; the international code is definitely not needed.
everyday
Message 6 of 11
Thanks very much - that's a great help!
Message 7 of 11
Well done Potters.  Smiley Happy
Now, just for the record, as someone's bound to ask it one day, does it work from within KGB Headquarters inside the Kremlin I'm wondering? Smiley Tongue
AQ.
"Welcome to Royston Vasey - You'll never leave."
pottyperson
Distinguished Guru
Distinguished Guru
Message 8 of 11
Я скажу вам, когда я добираюсь до России.
Message 9 of 11
Удачи!
AQ.
Max_mclellan
Message 10 of 11
Having just got back from the States, we used the app over there frequently to call the UK. Works just like you were in the UK. Very impressed ! Very simple and easy. Be aware of the wifi speed for the connection you have in the states as this can cause some break up on the call. In the main we found this ok, but worth thinking about before you make the call.
