cpf
Message 1 of 42
Help with slow speeds please
Hi,  I'm a new BT customer & have waited over the 10 day "settling in"time & am finding my broadband speed to be very slow.  I've run the speed test & got the following result
1. Best Effort Test: -provides background information.
 Download  Speed
 0.32 Mbps
0 Mbps0.5 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.32 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
 Additional Information:
 Your DSL Connection Rate :0.8 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.5 Mbps
As a  comparison, I've looked back at the stats that I got with my old provider on the same test site & using the same equipment & found a download speed of 1134Kbps, with a stated acceptable range of 400 - 2000Kbps.  DSL connection rate 1632Kbps (Download) & 448Kbps (Upload) and an IP line profile of 1250 Kbps.
I am connected directly into the master socket & am using a wired connection.
Thanks for any help you can give.
41 REPLIES 41
Keith_Beddoe
Message 2 of 42
Re: Help with slow speeds please
Can you please display your ADSL stats
cpf
Message 3 of 42
I'm not currently using the Home Hub but these are the figures from my D-Link router.  Hope this is OK but if not, I'll unpack the Home Hub.
Mode:G.DMT
Type:ANNEX_A
Status:Showtime
 DownstreamUpstream
Rate (Kbps):800 kbps448 kbps
SNR Margin (dB):9.09.0
Attenuation (dB):63.531.5
Output Power (dBm):13.512.5
Super Frames:2590869625908696
RS Correctable Errors:040
RS Uncorrectable Errors:146412418
HEC Errors:208641040
Total Cells:1593226263
Data Cells:79459814155031
Bit Errors:00
Keith_Beddoe
Message 4 of 42
There is not enough information from the D-Link router to diagnose the problem.
Could you try the home hub please?
You should be connecting at about 1952Kbs.
john46
Message 5 of 42
hi you have a higher than normal noise margin the normal default is 6dB this will be limiting your connection speed unfortunately you stats do not show any connection time also have you tried connecting to the test socket at the rear of the removable lower panel of the master socket
cpf
Message 6 of 42
Thanks for the quick replies.  John, Yes, I've tried the test socket with no real difference.  Keith, I'll connect using the home hub & then let it settle down & post the stats again tomorrow.
john46
Message 7 of 42
you would be best to connect the hub to the test socket please
cpf
Message 8 of 42
Just plugged the Home Hub into the test socket.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:13:58
Downstream:928 Kbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):4.4 dB / 10.0 dB
Line attenuation (Down/Up):73.6 dB / 31.5 dB
Output power (Down/Up):15.6 dBm / 12.5 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):56 / 3
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):39 / 0
Error Seconds (Local/Remote):36 / 3
imjolly
Message 9 of 42
with your current attenuation and noise margin already at 4.4db I can'tsee you get much better than you have - about 1mb
john46
Message 10 of 42
hi those stats look much better your noise margin has improved and your connection speed is slightly better
it is also reporting you are on a much longer line the the dlink was this often the case as some hubs have a problem reporting attenuation figures on long lines
