john46
Message 21 of 42
Re: Help with slow speeds please
astar27 i will point you to this part of the posters comments
"TalkTalk days, my IP profile was quoted as 1250Kbps (which I assume to be 1.25Mbps"
astar27
Expert
Message 22 of 42
john46 i will point you also to part of the posters comments "TalkTalk directed me to the exact same speed test site" which indicates the bt speedtester, tt have ipstream customers aswell
john46
Message 23 of 42
agreed they do
cpf
Message 24 of 42
Don't wish to interupt your argument gents but if it helps, my exchange is not LLU so as I said, TalkTalk would have been providing a much faster (relatively) service using the same equipment.  Anyway, back to the original problem.  I've done another speedtest this morning & got the worst result so far.  The service is so slow that I did not think that the page was going to load.  Here's the results
1. Best Effort Test: -provides background information.
 Download  Speed
 0.05 Mbps
0 Mbps1 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.05 Mbps
 For your connection, the acceptable range of speeds is 0.2 Mbps-1 Mbps.
 Additional Information:
 Your DSL Connection Rate :0.93 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.75 Mbps
The Home Hub router stats are now as follows,
ADSL Line Status
Connection Information
Line state:Connected
Connection time:3 days, 15:34:32
Downstream:928 Kbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):3.5 dB / 10.0 dB
Line attenuation (Down/Up):73.6 dB / 31.5 dB
Output power (Down/Up):15.6 dBm / 12.5 dBm
FEC Events (Down/Up):0 / 53261
CRC Events (Down/Up):5541224 / 40204
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):2739191 / 4294949595
Error Seconds (Local/Remote):288578 / 54205
So can someone please tell me how I can get help with this rather than suggesting it's the best I'm going to get.   Thanks again.
john46
Message 25 of 42
Hi you are on a very long line and your noise margin is already at the lowest level there is basically no room for any speed improvement your line is very stable
You could try connecting to the test socket and see if there is any improve ment there And post back the results
If there is any improvement you could try removing the bell wire from terminal 3 on all phone sockets
Then post back
If
imjolly
Message 26 of 42
sorry but I agree with john46 that with your attenuation you are a long way from the exchange and a conenction speed of about 1/1.2 mb is about as good as you will get and then that is on a good line with no noise.  try the suggestions john46 made of test socket and also removing the bellwire
bellwire removal
cpf
Message 27 of 42
The test results posted above were made using the test socket.  Don't think that I'm any further away from the exchange with BT that I was with TalkTalk but I can have a look outside to see if my house has moved.
cpf
Message 28 of 42
Nope.....still where I left it!
john46
Message 29 of 42
Then i am sorry you are on the best speed you are likely to get there is little that can be done to improve your connection my only suggestion would be get a BT Business hub 2700 or 2701 they are well known to work well on long lines they can be purchased from a well known auction site but make sure you buy a boxed one
cpf
Message 30 of 42
The latest test results are as follows.
 Download  Speed
 0.46 Mbps
0 Mbps1 Mbps
 Download speedachieved during the test was - 0.46 Mbps
 Your DSL Connection Rate :0.96 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
Once again, I'm not a techie so I don't understand (or really care) what the numbers mean.  All I know is that the numbers used to be higher & my broadband used to be faster.  So it's obviously not an impossiblity for it to be faster coz it was!
