Lfoster1258
Message 1 of 6
Help!!!
Hello
In desperate need of help
On New Years this year my line kept disconnecting and reconnecting for 2 days. After this my line was stable however my internet was very slow suddenly!I was now getting a download speed of just 0.4mbps!
After having an engineer visit who re wired the sockets in my house and fixed a loop fault I was expecting the speeds to increase within 4 days however this didn't happen!
So a new hub was ordered and after connecting the hub no speed improvements!
BT are now sending a broadband engineer but after some reasearch it looks like I have a banded profile that's capped
Is there anyway a mod could do me a reset???
Thanks in advance
Tags (1)
5 REPLIES 5
Webby
Message 2 of 6
Re: Help!!!
Can you post the connection stats from the hub?
What speeds do you usually get?
Can you also post the results for your line from this checker http://www.dslchecker.bt.com
Lfoster1258
Message 3 of 6
Re: Help!!!
Hi
Adsl stats
Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High Low High Low
VDSL Range A (Clean) 62.9 46.1 18.1 12.3 -- Available -- Yes Yes --
VDSL Range B (Impacted) 47.7 27.3 14.5 6.8 -- Available -- Yes Yes --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 8 -- 7.5 to 8.5 Available -- -- -- --
WBC ADSL 2+ Annex M Up to 8 Up to 1 7.5 to 8.5 Available -- -- -- --
ADSL Max Up to 5.5 -- 4 to 8 Available -- -- -- --
WBC Fixed Rate 2 -- -- Available -- -- -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- -- -- --
ADSL Multicast -- -- -- Available --
Router stats I assume this is correct
69776.240000) DSL noise margin: 5.70 dB upstream, 25.00 dB downstream
17:09:27, 11 Jan. (69775.550000) DSL line rate: 910 Kbps upstream, 286 Kbps downstream
Keith_Beddoe
Message 4 of 6
Re: Help!!!
Welcome to this user forum.
If you leave things alone, they will get better on their own. A visit from Openreach will be a waste of time.
See this post.
https://community.bt.com/t5/ADSL-Copper-Broadband-Speed/How-to-speed-up-return-to-normal-ADSL-speeds...
Webby
Message 5 of 6
Re: Help!!!
Are you aware you can get BT Inifinity?
Lfoster1258
Message 6 of 6
Re: Help!!!
Yes unfortunately right now I can't afford the extra money monthly
