Bert93
Message 1 of 23
Help?
Hello I was just curious on how slow my Internet download speed is. I'm currently on the Ultimate BT Package, using the BThomehub2, I'm using windows 7 if this is any help.
Also my wireless connection keeps dropping out which requires me to reset the Hub which annoys me as it drops out constantly.
** I haven't tried Wired Connection as I don't want wired I want Wireless.
Please help and if any more information is needed, please ask as this is so annoying and I really need advice and help!
Thanks! 😞
___________________________________________________
Kind Regards, Bert
22 REPLIES 22
Diean
Message 2 of 23
Re: Help?
Please post your hub stats from the hub manager http://bthomehub.home and speed test result from www.speedtester.bt.com  thank you.
Bert93
Message 3 of 23
Re: Help?
I'm currently at work at this precise moment, but I will post them up in a couple of hours when I finish, thanks 🙂
Kind Regards, Bert
Message 4 of 23
Re: Help?
i understand you do not want wired connection but wireless can suffer from many causes of interference that can cause wireless drop outs the most likely being other wireless routers(hubs ) operating nearby a wired connection will always give the most stable and secure connection you will also get the best download speed from a wired connection worth considering i think personally
Bert93
Message 5 of 23
Re: Help?
John, thanks for a solution.
Preferably I would like to atleast try and sort my wireless problem out first before I even think about going wired... I also have laptops and other computer consoles such as playstations, xbox's ..
Kind Regards, Bert
Bert93
Message 6 of 23
Re: Help?
Kind Regards, Bert
Bert93
Message 7 of 23
Re: Help?
ADSL line status
Connection information
Line state
Connected
Connection time
0 days, 19:38:41
Downstream
4,544 Kbps
Upstream
732 Kbps
ADSL settings
VPI/VCI
0/38
PPPoA
Modulation
ITU-T G.992.5
Latency type
Interleaved
Noise margin (Down/Up)
9.2 dB / 4.2 dB
Line attenuation (Down/Up)
49.5 dB / 27.2 dB
Output power (Down/Up)
19.5 dBm / 12.4 dBm
Loss of Framing (Local)
0
Loss of Signal (Local)
0
Loss of Power (Local)
0
FEC Errors (Down/Up)
0 / 1
CRC Errors (Down/Up)
1551 / 2147480000
HEC Errors (Down/Up)
nil / 516110
Error Seconds (Local)
563
Kind Regards, Bert
Message 8 of 23
Re: Help?
you don't need a service id just phone number is sufficient for btspeedtester to run
are you connected directly to the NTE5 master or test socket or to somewhere else? Do you have any phone extension sockets in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
Bert93
Message 9 of 23
Re: Help?
Performance Tester is unable to run the speed test for your telephone
number:0191xxxxxxx. Please check that it is the correct telephone number for
your service. Did you follow all the instructions given on the website, before
initiating the speed test. If not, then please follow all the instructions
carefully and try to run the test again.If you believe it is the correct number
for your service and you have followed all the instructions then please ask your
Service Provider whether you can use Performance Tester to test your Broadband
speed. If yes, then ask him for the Service ID of your broadband connection and
try again with this Service ID along with your Telephone Number. If this problem
persists, raise the issue with your service provider.
 im connected to the NTE5 which is fitted to the microfilter then to router...? ive tried the 17070 test with a cordless phone and hear a slight dull humm.
Kind Regards, Bert
Distinguished Guru
Message 10 of 23
Re: Help?
Hi bert93. you should edit your post to remove your telephone number from the post, its a public forum and the number is viewable by anyone
toekneem
(EASBF)
