Expert
Message 1 of 5
Here we go again!!!!!!!!!!!!!!!!!!!!
No problems then eh?????????????????????
1. Best Effort Test: -provides background information.
Download Speed
8223 Kbps
0 Kbps38717 Kbps
Max Achievable Speed
> Download speedachieved during the test was - 8223 Kbps
 For your connection, the acceptable range of speedsis 12000-38717 Kbps .
 Additional Information:
 IP Profile for your line is -38717 Kbps
2. Upstream Test: -provides background information.
Upload Speed
8119 Kbps
0 Kbps10000 Kbps
>Upload speed achieved during the test was - 8119 Kbps
 Upstream Rate IP profile on your line is - 10000 Kbps
4 REPLIES 4
Expert
Message 2 of 5
Re: Here we go again!!!!!!!!!!!!!!!!!!!!
And I am also fed up with this:
System Error Image not loaded
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
I have NEVER yet been able to run the 3rd test. This really is a piled up load of horse pooh!
BTVision? refusing to download because I 'do not have the bandwidth'!!!!!!
Message 3 of 5
I was having similar problems... you are a bit stuck in that it is now the weekend and most of the decent staff who know what they are doing will have gone home.
email  forum.moderation.team@bt.com
use the subject FAO SeanD  Infinity speed problem
give him your account number and phone number, tell him you want to speak to tier 2 support
they are now working on my line and touch wood this weekend mine seems to be a lot better
the first thing they asked me to do which helped initially was power down both white VDSL modem and black hub, power up the modem first, wait till both green lights come on, then power up the black hub
the way the system is supposed to work is that 1st line support run a simple line check, if this shows a problem they are supposed to put you through to tier 2, however whenever I've called they put you on hold then cut you off and you never get to speak to tier 2
if the call center in India refuse to put you through to tier 2, tell them you want to speak to the Infinity Options team to talk about cancelling your account, when you get through to options, explain to them your situation and ask to speak to tier 2, they will then put you through successfully
or ask one of the moderators on here to get you in touch with tier 2, they should be able to
of course tier 2 are probably all off work over the weekend, so try again on monday
Expert
Message 4 of 5
Hi andybird456
I already have a call back from BT in Newcastle for Monday or Tuesday evening.
Latest stats:
Download Speed
11242 Kbps
0 Kbps38717 Kbps
> Download speedachieved during the test was - 11242 Kbps
Upload Speed
8156 Kbps
0 Kbps10000 Kbps
>Upload speed achieved during the test was - 8156 Kbps
Expert
Message 5 of 5
Right here we are peak hour.
Just turned back on the modem and hub, so bascially  starting from fresh: Question is just why should this bring the speed back up if their is no problem on the network?
Answers on a very small post card please:)
Stats as follows:
FAQ
Results Image not loaded
Test1 comprises of two tests
Download Speed
29766 Kbps
0 Kbps38717 Kbps
> Download speedachieved during the test was - 29766 Kbps
Upload Speed
8165 Kbps
0 Kbps10000 Kbps
>Upload speed achieved during the test was - 8165 Kbps
