john46
Message 11 of 18
Re: High Noise Margin - Inconsistent Speed
ok post back when you are ready
ben_the_wad
Message 12 of 18
After three days of constant connection, using the test socket, the line status is as follows:
Line state:Connected
Connection time:3 days, 07:25:55
Downstream:7,703 Kbps
Upstream:1,183 Kbps
   ADSL settings
VPI/VCI:
0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):13.7 dB / 6.2 dB
Line attenuation (Down/Up):36.5 dB / 21.3 dB
Output power (Down/Up):0.0 dBm / 12.4 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):2579 / 154
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):7630 / 96
Error Seconds (Local/Remote):0 / 138
And speedtester.bt.com results are:
john46
Message 13 of 18
Hi I suggest you contact the forum mods they should be able to get your noise margin reset for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
ben_the_wad
Message 14 of 18
Thanks for the speedy reply again!
I have contacted the mods, and will update the thread when the issue is resolved.
Thanks,
Ben
john46
Message 15 of 18
ok post back when the reset has been done with new hubstats and a speedtest
ben_the_wad
Message 16 of 18
Hi,
Sorry for the delay in posting back.
After almost a fortnight since the noise margin was reset, the connection has been greatly improved (~12Mbps, ~6dcb noise).
Thanks for the help,
Ben
imjolly
Message 17 of 18
that's great thanks for posting - always good to hear a positive outcome
john46
Message 18 of 18
thanks for posting back glad all is now ok 🙂
