Message 1 of 18
High Noise Margin
Hi
How long do i realistically have to wait for DLM or whatever controls it to lower my noise margin.
Its been stuck around 10.5 for ages ?
Some stats below ....
This is a list of your BT Smart Hub settings and current statistics.
Product name: BT Hub 6A
Serial number: +084319+NQ
Firmware version: SG4B100021F4
Firmware updated: 22/06/16
Board version: 1.0
Gui version: 1.28.3
DSL uptime: 14 Days, 2 Hours 7 Minutes 25 Seconds
Data rate: 20.00 kbps / 49.00 kbps
Maximum data rate: 20068 / 65093
Noise margin: 5.9 / 10.4
Line attenuation: 19.3
Signal attenuation: 0 / 193
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 3724 MB Uploaded / 2977 MB Downloaded
Im sure i should have more download speed as im syncing at 65Mb/s
17 REPLIES 17
Message 2 of 18
Re: High Noise Margin
You're on a banded profile, likely due to a historic unstable connection.
It can take months for a banded profile to be released.
Message 3 of 18
It will be released on the 12th of never. Smiley Wink
Message 4 of 18
So I'm paying for Infinity 2 but they have no intention of giving me it ?
Message 5 of 18
No one is intentionally preventing you from accessing the higher speeds.
DLM is wholly automated.
What are the results for your line when using http://www.dslchecker.bt.com
Message 6 of 18
Message 7 of 18
We did have a lot of power cuts 5 months or so ago as the power company were replacing telegraph poles etc . It was around 10 cuts in as many days.
But that wouldnt have just been me ..... that would be the same for virtually half of the village where we live so doesnt the system take that into account when a whole village goes of instead of just me lol .
Message 8 of 18
In theory it does, DLM regards it as a wide area fault and should ignore it. It should also release banding, but it doesn't always do that either. Smiley Frustrated
Message 9 of 18
Isnt it time one of the mods looked into this for me as BT in a forgien country arent listening and say 45M/bs is all i can achieve even though i used to get 68 + mb/s .... and i have never ever had that speed and calling me a liar etc ????
Message 10 of 18
Not quiet.
You need to call the helpdesk and request an engineer visit as you're connected below the expected range for your line.
