Message 1 of 4
High Noise Margin
I have a high noise margin on my my line causing slow download speeds.
FAQ
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
 Download  Speed
 1350 Kbps
0 Kbps2000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 1350 Kbps
 For your connection, the acceptable range of speeds is 400-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :2336 Kbps(DOWN-STREAM), 224 Kbps(UP-STREAM)
 IP Profile for your line is - 2000 Kbps
  ADSL Line Status
Connection Information
Line state:Connected
Connection time:4 days, 04:42:00
Downstream:2.281 Mbps
Upstream:224 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):34.5 dB / 6.0 dB
Line attenuation (Down/Up):15.7 dB / 10.0 dB
Output power (Down/Up):20.0 dBm / 12.3 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):965 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):136 / 0
Error Seconds (Local/Remote):1807 / 203
3 REPLIES 3
Message 2 of 4
Re: High Noise Margin
contact the mods and get it reset back to 6  http://bt.custhelp.com/app/contact_email/c/4951
can take 3 days for a reply
Message 3 of 4
Ok thank you 🙂
Message 4 of 4
Hi The mods normally reply by email or phone directly to you within 72 hours
They are a UK based specialist team who have a good record at getting problems solved
