HBomb
Message 11 of 41
Re: High Ping and Packet Loss in Online Games
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068534+NQ45000550
3. Firmware version:Software version 4.7.5.1.83.8.130.1.26.1.1 (Type A) Last updated 19/10/15
4. Board version:BT Hub 4A
5. ADSL uptime:0 days, 00:58:20
6. Bandwidth:448 / 8128
7. Data sent/received:21.7 MB / 414.4 MB
8. Broadband username:bthomehub@btbroadband.com
9. BT Wi-fi:Yes
10. 2.4 GHz Wireless network/SSID:BTHub4-8PXF
11. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security:WPA and WPA2
13. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID:BTHub4-8PXF
15. 5 GHz Wireless connections:Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security:WPA2
17. 5 GHz Wireless channel:Automatic (Smart Wireless)
18. Firewall:Default
19. MAC Address:18:1e:78:28:9f:10
20. VPI/VCI:0 / 38
21. Modulation:G.992.1 Annex A
22. Latency type:Interleaved
23. Software variant:-
24. Boot loader:-
john46
Message 12 of 41
once you can shoe 3 days+ stable connection post back the helpdesk page and we can ask the forum mods to change you to fast path that should help your latency
HBomb
Message 13 of 41
So is my connection stable at the moment? beacuase I am still getting lag in the game.
Latest tracert:
Tracing route to lux.valve.net [146.66.152.2]
over a maximum of 30 hops:
1 1 ms 1 ms <1 ms BThomehub.home [192.168.1.254]
2 26 ms 26 ms 27 ms 217.47.105.122
3 26 ms 26 ms 25 ms 217.47.106.161
4 165 ms 104 ms 88 ms 213.1.69.166
5 43 ms 41 ms 44 ms 31.55.165.102
6 36 ms 36 ms 37 ms 31.55.165.75
7 * 181 ms 176 ms 31.55.165.107
8 226 ms 254 ms 190 ms 109.159.250.54
9 43 ms 43 ms 43 ms 109.159.255.147
10 50 ms 51 ms 57 ms peer2-xe4-0-1.telehouse.ukcore.bt.net [109.159.252.39]
11 323 ms 322 ms 309 ms 109.159.253.91
12 88 ms 91 ms 97 ms 162-254-196-137.valve.net [162.254.196.137]
13 58 ms 57 ms 58 ms 146.66.154.218
14 * * * Request timed out.
15 57 ms 57 ms 57 ms 146.66.152.2
Trace complete.
john46
Message 14 of 41
your hub needs to show 3days+ connection time before anything can be done to change your latency
HBomb
Message 15 of 41
OK thanks for the help. So in three days I post my Helpdesk page and the mods will fix the issue?
john46
Message 16 of 41
the mods can be asked to change your latency to fast path which should improve your latency
HBomb
Message 17 of 41
Should I create a new thread in 3 days or just post back here?
john46
Message 18 of 41
post back on this thread do not start a new thread
HBomb
Message 19 of 41
OK thanks. So is this an issue on my end or an ISP routing issue?
john46
Message 20 of 41
it is not a routing issue interleaving was turned on on your line to stabilise the connection this is an automatic process turning it off should improve the latency
this link explains more http://www.kitz.co.uk/adsl/interleaving.htm
