MrVW
Message 1 of 4
High Ping
Good Morning All,
Ive been experiencing very high ping times when playing my games recently (approx 2 weeks that i can gather),  i will start my game which in this case ive experienced this on two of them, Shootmania and Counterstrike GO (PC Games).
I can connect to the servers fine, but after a random amount of time sometimes instantly sometimes after 5/10 minutes or so pings will rise up to 800/1500 and stay there, ive not managed to stay on a server long enough to find out if they return to normal.
ive not managed to do any trace routes yet but i will attempt this tonight, just seems wierd, nothing has changed on my network/computer so my only guess is that this is something external / BT related.
Kind Regards,
Steven
3 REPLIES 3
Message 2 of 4
Re: High Ping
hi are you connecting to the home hub to the Pc/Games system by wireless or wired connection
MrVW
Message 3 of 4
Re: High Ping
Sorry, yes this is a wired connection, a speedtest at speedtest.net gives me a ping of around 50ms which is normal for me.
Message 4 of 4
Re: High Ping
hi when you do your next ping test can you do it from command prompt on you PC to remove any outside influences
