Xtrato
Message 1 of 12
High error rate causing my problem?
I woke up this morning and my connection in unusually slow. It is usually slow anyway because of the distance I am from the exchange but it's worse today.
I have had a look at the BTHOMEHUB settings and it is saying I have a lot of errors on the line.
ADSL line status
Connection Information
Line state
Connected
Connection time
0 days, 06:46:25
Downstream
768 Kbps
Upstream
448 Kbps
ADSL Settings
VPI/VCI
0/38
PPPoA
Modulation
G.992.1 Annex A
Latency type
Interleaved
Noise margin (Down/Up)
15.6 dB / 15.0 dB
Line attenuation (Down/Up)
65.3 dB / 31.5 dB
Output power (Down/Up)
1.5 dBm / 1.2 dBm
Loss of Framing (Local/Remote)
0 / 0
Loss of Signal (Local/Remote)
0 / 0
Loss of Power (Local/Remote)
0 / 0
FEC Errors (Down/Up)
11774 / 585
CRC Errors (Down/Up)
29629 / 458
HEC Errors (Down/Up)
40555 / 370
Error Seconds (Local/Remote)
8823 / 663
I understand that there is always going to be some errors because of my high attenuation on the line but is this many a usual amount?
Also, my Error Seconds (Local/Remote). does the 8823 for local mean errors on my local network? And if so I assume this means that my problem is locally and not outside my home?
Thank you in advance for your help
James
11 REPLIES 11
imjolly
Message 2 of 12
Re: High error rate causing my problem?
your connection has reset as connection time only 6hrs.  your noise margin is hight at 15.6 as normal about 6db suggesting when you take into account the high errors a problem with noise on your line.
are you connected to test or master socket?  do you have other sockets?
john46
Message 3 of 12
Here are some help pages done by CL Keith http://forumhelp.dyndns.org/speed/Speed.html
Can you also post the full results from BT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket  Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
Xtrato
Message 4 of 12
Yes I am connected to the master socket. There is also only 1 socket in my home. I don't have any extensions.
imjolly
Message 5 of 12
have you tried connecting to the test socket as that should be your best connection as direcrt to the exchange.  if you connect to test with new filter can you post new stats please
john46
Message 6 of 12
have you tried the quiet line test also have you tried changing the filter ?
Xtrato
Message 7 of 12
Ok I just tried a new filter plugged directly into the Test Socket. Below is what it says now.
I also just did a quite line test. I can't hear any crackles or anything of that nature. Just a quite line.
ADSL line status
Line state
Connected
Connection time
0 days, 00:12:24
Downstream
832 Kbps
Upstream
448 Kbps
ADSL Settings
VPI/VCI
0/38
PPPoA
Modulation
G.992.1 Annex A
Latency type
Interleaved
15.3 dB / 15.0 dB
65.8 dB / 31.5 dB
1.7 dBm / 1.2 dBm
0 / 0
0 / 0
0 / 0
65 / 6
24 / 5
11 / 0
19 / 1
john46
Message 8 of 12
could you post back in a few hour your hubstats again as the current connection time is low
imjolly
Message 9 of 12
connection speed only slightly better with noise margin still high.  your power output is a lot lower than I would expect.  errors are low but that may well be due to you just resetting and not due to the change to the test socket
john46
Message 10 of 12
output power is very low as i posted repost stats later then you may need the mods help
