barnettgs
Message 1 of 6
High error rate
Since my request for fastpath has been refused due to high error rate some months ago, my line has not been great and sometimes it can a bit unstable, e.g. not responding.
Basically, it has not been good since new line was installed in December 2015.
Here is my modem stats for nearly 7 days now.
6 Day(s) 23:19:36
Mode:ADSL_G.dmt
Traffic Type:ATM
Status:Up
Link Power State:L0
 DownstreamUpstream
Line Coding(Trellis):OnOn
SNR Margin (0.1 dB):94210
Attenuation (0.1 dB):555315
Output Power (0.1 dBm):185123
Attainable Rate (Kbps):3,9681,136
 Path 0 Path 1
 DownstreamUpstreamDownstreamUpstream
Rate (Kbps):3,48844800
K (number of bytes in DMT frame):1101500
R (number of check bytes in RS code word):121600
S (RS code word size in DMT frame):2.008.000.00.0
D (interleaver depth):32800
Delay (msec):16.0016.000.00.0
INP (DMT symbol):0.830.260.00.0
Super Frames:35,395,75135,395,75100
Super Frame Errors:4,0659100
RS Words:1,203,455,501301,170,79300
RS Correctable Errors:9,324,76010200
RS Uncorrectable Errors:54,033000
HEC Errors:52,72716800
OCD Errors:55000
LCD Errors:55000
Total Cells:655,034,237000
Data Cells:46,250,960000
Bit Errors:0000
Total ES:1,0160
Total SES:220
Total UAS:2929
5 REPLIES 5
imjolly
Message 2 of 6
Re: High error rate
Did you check quiet line test for line noise?
barnettgs
Message 3 of 6
Re: High error rate
There's no phone equipment or anything connected to the master socket, other than just the router.
By the way, I'm deaf, how can I hear?
john46
Message 4 of 6
Re: High error rate
could you ask a family member or friend to do the quiet line test at the test socket without doing the test there is no way of telling if you have a line fault also using the test socket will eliminate the possibility of you being charged if an engineer visit is needed
barnettgs
Message 5 of 6
Re: High error rate
Unfortunately, I have had no-one coming for weeks.  I have realised that both lines are terrible.
Here is the latest stats for the original line, the connection has been up for 7 days and 19 hours & 16 minutes.
john46
Message 6 of 6
Re: High error rate
until you can get any line noise fixed your broadband will not improve
