Message 1 of 17
High latency/MS at prime time.
Hello there,
Over the last few weeks I've been experiencing very high latency/MS/Ping to a number of different servers.
This occiurs almost soley in prime time, where my usual latency of about 30 goes up to 300-500 for about 6 hours between 6 and midnight.
I've tried this to severl different servers, from google.com to testing it via pingtest.net
http://www.pingtest.net/result/82927079.png
The speed of my connection seems to be relatively unaffected, just the latency goes right up.
Does anyone have any ideas?
Thank you for your help.
16 REPLIES 16
Message 2 of 17
Re: High latency/MS at prime time.
connected wifi or ethernet?
Message 3 of 17
Wifi currently.
Thank you for your reply.
Message 4 of 17
could you try with a wired connection as you may have a wireless interference problem causing a lot of data resends
Message 5 of 17
I just tested with a wired connection, I get the same result.
Message 6 of 17
could you post some trace routes to the sites you are having trouble with
Message 7 of 17
I'm sorry, could you explain how to do that please?
Message 8 of 17
go to windows command prompt type in tracert bbc.co.uk
and when complete post back the result
also  post your hub stats  and the further diagnostics part of the BT speedtest  http://speedtest.btwholesale.com/
Message 9 of 17
First trace.
Tracing route to bbc.co.uk [212.58.253.67]
over a maximum of 30 hops:
1 1 ms 3 ms 4 ms BThomehub.home [192.168.1.254]
2 687 ms 591 ms 438 ms 217.32.147.8
3 594 ms 702 ms 596 ms 217.32.147.78
4 680 ms 373 ms 21 ms 213.120.177.74
5 411 ms 424 ms 431 ms 217.41.168.243
6 591 ms 260 ms 19 ms 217.41.168.109
7 20 ms 19 ms 19 ms acc2-10GigE-0-7-0-4.l-far.21cn-ipp.bt.net [109.1
59.249.202]
8 19 ms 24 ms 23 ms core1-te0-15-0-16.faraday.ukcore.bt.net [109.159
.249.157]
9 20 ms 19 ms 23 ms peer2-xe8-1-0.telehouse.ukcore.bt.net [109.159.2
55.101]
10 20 ms 19 ms 18 ms 194.74.65.42
11 * * * Request timed out.
12 31 ms 23 ms 21 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
13 21 ms 21 ms 20 ms 132.185.255.156
14 23 ms 21 ms 22 ms www-vip.cwwtf.bbc.co.uk [212.58.253.67]
Trace complete.
Second Trace.
1 1 ms 2 ms 2 ms BThomehub.home [192.168.1.254]
2 15 ms 16 ms 16 ms 217.32.147.8
3 17 ms 18 ms 19 ms 217.32.147.78
4 19 ms 18 ms 22 ms 213.120.177.74
5 309 ms 339 ms 375 ms 217.41.168.243
6 395 ms 388 ms 410 ms 217.41.168.109
7 363 ms 308 ms 321 ms acc2-10GigE-0-2-0-5.l-far.21cn-ipp.bt.net [109.1
59.249.227]
8 363 ms 376 ms 358 ms core1-te0-15-0-16.faraday.ukcore.bt.net [109.159
.249.157]
9 348 ms 354 ms 399 ms peer2-xe8-1-0.telehouse.ukcore.bt.net [109.159.2
55.101]
10 407 ms 378 ms 402 ms 194.74.65.42
12 356 ms 397 ms 424 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
13 478 ms 440 ms 353 ms 132.185.255.156
14 424 ms 456 ms 472 ms www-vip.cwwtf.bbc.co.uk [212.58.253.67]
Trace complete.
Further Diagnostics
  1. Best Effort Test:  -provides background information.
 Download Speed
 24.13 Mbps
0 Mbps35.72 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 24.13 Mbps
 For your connection, the acceptable range of speedsis 12 Mbps-35.72 Mbps .
 Additional Information:
 IP Profile for your line is - 35.72 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 1.66 Mbps
0 Mbps2 Mbps
Upload speed achieved during the test was - 1.66Mbps
 Upstream Rate IP profile on your line is - 2 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Hub Stats
For some reason, under Broadband > Connection in the homehub, this is all I have.
WAN Status
Connection Information
Line state:Connected
Connection time:0 days, 15:03:22
Message 10 of 17
 you are  on infinity ???
I  will move your post to the INFINITY Board
