DaJoHo
Message 1 of 4
High ping / latency and packet loss on broadband - potential causes?
Looking for similar experience and any insights to help find a solution.
I am getting a generally high ping latency and frequent high (>30%) packet loss on BT broadband (copper).
When running BT Speedtest i sometimes also get return of a grey exclamation mark and no results. This also sometimes result in an 'error #2032' appearing as another alternate to results. Results for upload can be as low as 0.02 and up to 0.48 (which would be great). Download vary from 1mb to 6mb.
Doesnt seem to matter if device is wired or wireless. Whenever traffic hits internet the quality of service degrades.
I have been running pingplotter and the attached/below snip shows a snapshot particularly of the ping times in the 'CUR' column. These being pings hitting UKCORE.BT.NET and EU.BT.NET and GTT.NET with pings in excess of 1,000ms.
Welcome any thoughts/ideas from the communit to help me improve the service??
3 REPLIES 3
imjolly
Message 2 of 4
Re: High ping / latency and packet loss on broadband - potential causes?
can you post stats from your router
check for line noise  dial 17070 option 2 should be quiet and best with corded phone
run btspeedtester with ethernet conenction and when first test completes then run diagnostic test and post results  appears to work better with edge not firefox
are you using the test socjket with a filter to see if that helps by eliminating your internal wiring
DaJoHo
Message 3 of 4
Hi. Done quiet line test. Nothing of note so seems ok.
Diag tests from BT Speedtest below. Speed itself on a point test is generally ok.
Issue is the ping/packet loss shown earlier.
Will try test socket directly. I have tried two other routers.
Why would BT Speedtest give the grey exclamation mark as a result?
DaJoHo
Message 4 of 4
@imjolly any further thoughts?
