Certi
Message 1 of 10
High ping/latency on Xbox Live
I currently have BT Infinity 2 on a Home Hub 5, but I'm having problems with the wireless connection on my Xbox One. My ping/latency is around 170ms.
On my wired PC my stats are as follows:
Download: 37.35mbps
Upload: 9.34mbps
Ping: 38
On my iPad Air that is connected on the 5GHz setting I get:
Upload: 7.96
Ping: 56
But on my Xbox One I'm getting:
Upload: 3.28
Ping: 173
The Xbox is in the same room as the Home Hub (around 15ft away) and has full signal strength. I've tried it on 2.4GHz and 5GHz with no difference. Both show the NAT settings as "open". I've tried port forwarding and changing the channels, using InSSIDER to make sure I'm on the right channel but that has made no difference. I've reset the router and the console.
Can anyone suggest anything else to reduce the ping without having to go wired?
9 REPLIES 9
Message 2 of 10
Re: High ping/latency on Xbox Live
Certi
Message 3 of 10
Thanks, but surely I shouldn't need an extender when the console is in the same room? As you can see from my original post, I have no issues with connectivity on my iPad that's the same distance from the Home Hub.
Message 4 of 10
if you want to do serious gaming then a wired connection is always reccomended due to wireless interference (not always caused by other routers)caused by other types of wireless devices can cause the re sending of data packets which will increase your latency
Message 5 of 10
In that case, run a direct Ethernet cable, wireless introduces quite a delay.
Certi
Message 6 of 10
Yeah I know wired will always give a better ping, but I'd rather not have a ethernet cable going along my wall if I can help it. I don't understand why my iPad and my phone both have pings below 50 but the Xbox is up at 170. Man Frustrated
Thanks for the replies so far guys
pcfarrar
Message 7 of 10
The Xbox One network diagnostics pings Microsoft in seattle, thats why you get 170ms.
Malacath
Expert
Message 8 of 10
dont worry about the ping.  im wired and i get high ping. like the last poster said your xbox is pingin seattle
Toftman
Message 9 of 10
there's not much we can't tweak ,you could try not using a wireless connection most gamers would just hard wire , primary and secondary DNS server address , port forward xbox live on your hub ,
Good Luck
Toftman
Message 10 of 10
Forget using a wireless connection for gaming, just Hard wire, if you need a long cable use power line adapters,
do a factory restore on your hub and delete any old 360 Address's
set up your new one connection
try manual entry DNS Servers Ip
choice the best wireless channel on your router for your iPad/ phone
