arley
Message 1 of 8
High upstream noise margin
Hello all,
I've had repeated problems this year with my broadband downstream connection dropping coupled with an intermittent crackle on the line. We've had four engineer visits (three line engineers and one broadband engineer), one found a problem at the exchange but the problem persists. Whilst I understand that they cannot fix the fault if it isn't present when they are on site we are battling with a very slow upload speed. We are on ADSL2+ and about 2km from the exchange on an EO line. Have done the usual things like change filter, use master socket only, replace modem. Cable is underground all the way to the exchange. I currently seem to be able to get a stable connection for 3+ days (until either the phone support team ask me to reboot my modem or the engineer visits and disconnects it!) but still with occasional crackles on the home phone line.
Here's my HH4 connection stats:
15:52:08, 15 Jun.( 1303.260000) ETHoA is up -​ VPI: 0, VCI:35
15:52:08, 15 Jun.( 1303.250000) DSL is up
15:52:07, 15 Jun.( 1302.250000) DSL noise margin: 29.30 dB upstream, 6.00 dB downstream
15:52:07, 15 Jun.( 1302.190000) DSL line rate: 447 Kbps upstream, 17015 Kbps downstream
Here's the result of the broadband checker:
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
Other Offerings
Availability Date
WBC ADSL 2+Up to 14--12.5 to 16Available----
WBC ADSL 2+ Annex MUp to 14Up to 112.5 to 16Available----
ADSL MaxUp to 8--7 to 8Available----
Fixed Rate2----Available----
ADSL Multicast------Available--
Result from BT speed tester (from laptop as I don't have ability to connect to router wired but with all other devices OFF)
Download speed: 13.41Mbps
Upload speed: 0.36Mbps
Ping: 40.13ms
Is it possible to get the SNR margin reset to 6db to see if this increases our upload speed?
Thanks in advance!
7 REPLIES 7
imjolly
Message 2 of 8
Re: High upstream noise margin
I doubt from your stats that up noise margin was ever as low as 6db but see if mods can help improve your up speed  they will post a contact us link here
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 2/3 working days either by phone or email
JohnC2
Moderator
Moderator
Message 3 of 8
Hi @arley Welcome to the forum and thanks for posting about your broadband speed.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
arley
Message 4 of 8
Thanks for looking into this.....
imjolly
Message 5 of 8
did you complete the forum after following the mod contact us link?
arley
Message 6 of 8
Yes I did, so will wait until I'm at the front of the queue 🙂
arley
Message 7 of 8
Well big thanks to the team I seem to have got this problem sorted.
It appears that my ADSL profile upstream was 'stuck' at 448k despite me being upgraded to adsl2+ late last year. The mod (think it was Dave) got this changed and lo and behold my line reset itself this morning and I'm not connected:
10:07:54, 27 Jun.(1017416.010000) DSL noise margin: 6.00 dB upstream, 6.00 dB downstream
10:07:54, 27 Jun.
(1017415.510000) DSL line rate: 1259 Kbps upstream, 17079 Kbps downstream
Just did a speedtest using the BT tool and I'm seeing 14.58 down, 1.2 up, ping 37.63ms so a substantial improvement on before.
Many thanks!!
imjolly
Message 8 of 8
thats great
I think that is the highest upstream speed on adsl2+ that I can remember seeing
