Ogee
Newbie
Message 1 of 3
Home Hub 2.0 Admin password
I have reset my Home Hub 2 to factory setup by pressing the recessed red button. But when I go to bthomehub.home and enter the password printed on the back of the hub, it isn't recognised. There are 8 characters, these are either digits (3,6,7) or upper case letters (A,R,S,Z). No confusion about any of these, I'm sure I'm entering it correctly.  Is there something else I could try?
2 REPLIES 2
G3NDI
Message 2 of 3
Re: Home Hub 2.0 Admin password
Not sure if it will deal with your diffculty, but according to my HH2 Type B  User Guide the "Reset to Defaults" button needs to be depressed for at least 15 sec to make sure all settings  go to the factory default.
Rodney Fry
G3NDI
Ogee
Newbie
Message 3 of 3
Mine's type A, so I tried holding it for about 20 sec, worked a treat. Somewhere on the BT site I saw 4 seconds recommended,  obviously that's wrong.  Many thanks for your help.
