andres99
Message 1 of 3
Home Hub 2.0 - Automatic Configuration?
Hi all,
This evening I am going to go and look at a BT Home Hub 2.0 which is dropping wireless connections.
I have been told that the owner of the hub cannot get into it using the admin password (password is rejected)
I believe a full reset may be needed.
If I carry out a full reset on the router, will it automatically reconfigure itself and connect to BT broadband, or will I need to log on to it and provide connection details manually?
Many thanks
André
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Home Hub 2.0 - Automatic Configuration?
It will automatically configure.
There are known issues with the HH2.
http://forumhelp.dyndns.info/hardware/hh2/hh2_issues.html
imjolly
Message 3 of 3
after factory reset it should automatically connect to BT broadband without you doing anything  plug and play
