swaffie
Message 1 of 4
Home Hub 2 - unable to play MOH Heroes 2 (wii) online
Hi,
Just bought Medal of Honor Heroes2 for the wii. Tried to connect to EA servers but got no connection. Looked in Wii book and it said port forwarding required. So, checked on homehub and found MOH Heroes2 already included in applications list. Assigned it to the wii (static ip) but still no connection. Also tried turning off upnp as suggested. Other online games work OK. Looking at the port settings for the application on the HH2, they differ from the recommended ones in the wii game manual. Have tried adding these as well, but no luck. Anyone had any success in getting this game to work online?
Regards
Richard
3 REPLIES 3
Community Manager
Community Manager
Message 2 of 4
Re: Home Hub 2 - unable to play MOH Heroes 2 (wii) online
Hi Richard,
Are you able to connect OK when using other games? Are you connecting wirelessly?
Stephanie
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
swaffie
Message 3 of 4
Hi Stephanie
Yes, all other wii online games are ok. I am connecting wirelessly.
I suspect that EA Games no longer support this game server as the game is quite old - they quite often do this in order to target their developers/support teams at supporting the latest games. I am awaiting an email from EA Games to confirm if this is the case.
regards
Richard
Community Manager
Community Manager
Message 4 of 4
Hi Richard,
Looks like you're right, a quick Google search found this (from the EA website at http://www.ea.com/1/service-updates 😞
August 11, 2011 Online Service Shutdown
Medal of Honor Heroes™ 2 for PlayStation Portable and Wii
So that's why it didn't work. I never would've even thought of the server being shut down so thanks for sharing, it'll be something to bear in mind for future gaming queries 🙂
Stephanie
Kudos”
