Message 1 of 2
Home Hub 3 - 2 issues
Hi
Hope someone can help / offer advice.
I have a home hub 3 to which I connected a TPlink WA830 wireless extender as I have an old house and have dead zones. I also connected a old pc to the extender as it was not wireless enabled. All has ben great for over a year.
For Xmas I got a new laptop woith Windows 8.1. Set it up and everything was OK.
A few days later and my wireless extender upstairs is not working at all. Tried re-setting etc but to no avail.
Have also noticed that the Home Hub is also dropping off my connection when I am connected (via Ipad, Iphones)
Just wondering if anyone else is experiencing same thing ?
Only other thing i have done is upgraded by broadband to unlimited but don't think that should have affected it ?
Cheers
1 REPLY 1
Message 2 of 2
Re: Home Hub 3 - 2 issues
Probably someone else nearby has started using the same wireless channel as you, and its interefering with your connection.
Try changing the wireless channel to a different one, and see if it helps.
There is a free program which will help you find a clear channel http://www.inssider.com/
