andy203
Message 1 of 4
Home Hub 3 - Disable wireless ?
Hi,
Will be receiving my new HH3 soon - how do I disable the wireless capability?
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Home Hub 3 - Disable wireless ?
Very easily
When you get it, click this link - http://bthomehub.home/
You'll be asked to change the default admin password
Click A-Z (top right)
Select Wireless connections enable disable
Select no in the wireless network enable section and click apply
(Also to completely remove all wireless signals, opt out of BTFon - previous versions of the hub need this doing first, the hub3 is different)
-+-No longer a forum member-+-
andy203
Message 3 of 4
Thank you for that DS, I assume that you can only get to this page when the HH is up and running?
Distinguished Guru
Message 4 of 4
As long as it's connected to the mains, you can do what ever you want to do with it - change settings, configure all your devices to connect to it and then you can connect it to the line
