tculshaw
Message 1 of 10
Home Hub 3 PoE
Simple question that telephone support could not answer.
Does Home Hub 3 support Power Over Ethernet devices directly, or do I need to buy a booster or something, to fit between the hub and the device?
TIA, Tony
9 REPLIES 9
Message 2 of 10
Re: Home Hub 3 PoE
simple answer yes the hh3 does support and no to any form of booster
IanC
Recognised Expert
Message 3 of 10
Re: Home Hub 3 PoE
Power over Ethernet ≠ Ethernet over mains wiring.
Message 4 of 10
Re: Home Hub 3 PoE
Deleted by poster as not relevant.
Message 5 of 10
Re: Home Hub 3 PoE
Ethernet is Ethernet. It's a universal standard. Devices don't know or care what they're connecting to really, the Ethernet port takes care of it 🙂
tculshaw
Message 6 of 10
Re: Home Hub 3 PoE
Thanks to all for your reseponses.
John36 has given me exactly the information I need, so I can now buy a PoE IP Camera knowing it can be powered directly from the Hub.
Message 7 of 10
Re: Home Hub 3 PoE
The hub cannot supply power over the Ethernet connection, in fact if you apply any power to the connection, you are likely to damage the home hub.
You have to have a power injection and isolating splitter to prevent power getting back into the home hub.
tculshaw
Message 8 of 10
Re: Home Hub 3 PoE
We have a difference of opinion here, now who do I believe, John46 or Keith_Beddoe?
Keith, I don't want to apply power to the hub, I am expecting the hub to supply power to the camera.
Which one's right?
Key: <------> Ethernet cable
[Hub] <-----> [Camera]
or
[Hub] <----> [Isolating Splitter Power Device Thingy] <-----> [Camera]
Message 9 of 10
Re: Home Hub 3 PoE
I have spoken to John and he was getting confused between Power Over Ethernet and Ethernet over Power.
is the right answer.
tculshaw
Message 10 of 10
Re: Home Hub 3 PoE
Guys, you are stars. Thank you very much.
