slava125
Message 11 of 560
Re: Home Hub 3 Port Forwarding (NOT)
That works works in Hub v2 but not in v3.
Thanks for the tips with the loopback and disabling the upnp but it did not help.
Hope there is a solution soon.
MrP
Message 12 of 560
Have you tried accessing your external IP from a machine outside of your local network? And even then does it fail?!
Gizmo99
Message 13 of 560
Yes mate, I have 3 Boardband lines in the house
Virgin
BT Home
BT Work
And nope you get nuffin
We await a new version of Firmware
Giz
slava125
Message 14 of 560
Yes. Tried from work and mobile. No luck.
Gizmo99
Message 15 of 560
Bump any news ???? I don't want to buy a netgear or alike but at the mo hh3 is step backwards 😞
fishyuk
Message 16 of 560
I'll bump too, awful upnp and port forwarding experience with HH3. Have to revert to HH 1.5 to run any Games For Windows live or do remote access to my home server. Aaargh. Anyone from BT care to comment? Shoddy, very shoddy
STS
Message 17 of 560
The port forwarding on HH3 is fine the problem is loopback! - i need to edit preview and design websites and i only have one monitor and two computers at home - I host a website on my server using HH3 and people can log on to the page no problems i even used proxify to view it myself and it works - just not when viewing it on my own network -
Is there a way of editing the Loopback config in the router itself? and have it released as an update for the firmware
I changed over to HH3 because of the difficulties and grief i was having from HH2 - kept freezing on me because of the data transfers! now i am thinking that i need to just get a different router altogether! - though if i do this i promise that i will be sending the invoice to BT for the inconvienience they caused me!
fishyuk
Message 18 of 560
UPnP not working for me, I have another post which I'll dig out when not on phone but upnp only works on Xbox and XP for me. It doesn't work on Windows 7 64bit or 2008R2, Nor does it work on WHS V1 (2003 32 bit).
Gizmo99
Message 19 of 560
I know mate my Windows Home Server no dice as you say !
I want to work with BT to resolve this not start a "BT is ...."
Giz
fishyuk
Message 20 of 560
Would love to work with BT on this but not seeing any moderator input. Anyone know the best way to progress this ?
