ady199
Message 1 of 3
Home Hub 3 Problems
For some strange reason every morning I have to reboot my Home Hub 3 to get me a good connection speed.
Speed test (using speedtest.net) at 9.30am this morning - 19.26Mbps
Speed test (using speedtes.net) at 9.45am this morning (and after rebooting the Home Hub) - 36.05Mbps
This is the same every morning
Why should this be the case and how can I resolve th issue?
2 REPLIES 2
Message 2 of 3
Re: Home Hub 3 Problems
Hello ady199,
You don't by any chance use BT Vision do you? There was a small snag with BT Vision and the QoS used in the HH3. It's supposed to be fixed now though:
http://community.bt.com/t5/BT-Vision/BT-Vision-and-Infinity-Performance/td-p/27591
http://community.bt.com/t5/BT-Infinity/BT-Infinity-amp-Vision-Headache-Mods-please-look/td-p/168471
Hope this helps,
ady199
Message 3 of 3
Hi,
Thanks for your reply - nope don't have BT Vision.
It's just getting to be a pain
Speed test taken just after the router reboot (shown below)
It must be a problem with the router as connection seems fine
