Newbie
Message 1 of 2
Home Hub 3 and iPhone 4 wi-fi
Hi,
I received my BT Home Hib 3 yesterday, succesfully set it up to lap top with no problems but I cannot connect my iPhone to my hone hub only BT Openzone.
I have reset home hub
Changed password on Homehub
Cleared network settings from my phone
Tried using both old and new password
Hope someone can point me in the right direction or help.
Open to any help and advice is more than welcome.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Home Hub 3 and iPhone 4 wi-fi
Hi Warren5414 and welcome
I'm not an iPhone man myself but check your phone for any saved BTOpenzone and BTFon connections. If any are found, select each one in turn and select forget network.
Then see if you can connect to the hub3.
most phones retain the last wireless connection and try to connect to these first.
-+-No longer a forum member-+-
