mx5duncan
Message 1 of 3
Home Hub 3 and wireless N
Hi all,
Finally got BT to accept theres a problem with my home hub 2 and they are sending me the new home hub 3. However, I have heard that the new hub only operates with wireless N so does this mean my 8 month old laptop with wireless A, B and G will not work with the new hub without an adapter or will it work at 54mbps as with the home hub 2?
Duncan
2 REPLIES 2
Message 2 of 3
Re: Home Hub 3 and wireless N
The new HH3 is just the same as HH2 in that respect.  default is b/g/n but can be changed to just b/g if that suits you better
mx5duncan
Message 3 of 3
Thanks for your reply. As I will have 2 laptops connected wirelessly, one has wireless N and one is B/G is it worth buying a wireless N adapter for the B/G laptop? Your opinion is appreciated.
Cheers
Duncan
