smf22
Recognised Expert
Message 11 of 15
Re: Home Hub 3 to Smart Hub Upgrade
@cooljay. You can't use the OR modem with the FTTC variant of the Hub 6 as it has no WAN port.
Regards
ukhardy07
Message 12 of 15
If they had a HH5 I would have recommended using the modem as this doesn't reboot regularly like the homehub does, so generally DLM behaves a lot better... With the smarthub it's not possible to use a modem unless you have Infinity 3 and 4 and you get a slightly different variant for FTTH services.
cooljay
Message 13 of 15
Typo was meant to be hh4 and not6.
But openreach modem will work with hh3 and 4 as designed this way and hh5 if required.
The line management or slow down does not happen if the router reboots as the modem is still connected.
The older bbu batt back up kit was great for this as well.
mikeh01189
Message 14 of 15
Thanks for your post.  Good advice and v helpful.  I'm hoping it will help me sort out some wireless problems too.
pippincp
Message 15 of 15
Bottom line as always is don't use ISP supplied locked down, hogtied, onesizefitsall  inferior equipment.
