Message 51 of 54
Re: Does the Home Hub support DLNA working?
Quick update.
Most of my boxes now work . . . sort of with HH4.
They seem to take a little while to log in or whatever.
I also checked the names that HH4 was giving them and changed them to sommit simple.
I also ticked the box to keep the IP address the same.
It's still a bit iffy and completely different to HH2 which was seamless . . .
Maybe some firmware update will help . . . vamos a ver
Newbie
Message 52 of 54
Sorry to dig this up without being able to shed any new insights but I thought I'd share my situation:
Had dropouts etc. with HH3 so BT suggested HH4 - thought it couldn't hurt but sadly have not been impressed, DLNA or not.
Currently trying to work around some of the wi-fi issues with homeplugs. I had been blaming these for not being able to get Plex visible on my PS3 however I have ruled them out as the issue by plugging Server into homeplug then homeplug into PS3 - manual IP settings etc. got Plex to show up.
As soon as I introduce the HH4 into that setup, there's no sign of the media servers on the PS3. What perplexes me however is that they do show up if I connect the PS3 to the HH4 wirelessly. I really don't know enough about this to figure out what Wireless does differently to Wired but I've tried everything I can find online!
Signs are pointing to the HH4 being a bit of a mess when it comes to DLNA and having forked up money for it as a 'solution' after the HH3 disappointed, I can't help but feel aggrieved!
Newbie
Message 53 of 54
Re: Home Hub 4 and DLNA
Got my home hub 4 the other day, turned on my PS3 just now and found I couldn't see my dlna hdd, so I turned off the smart setup, as my dlna hdd can't type in log in details, restarted everything, so far so good, everything's working fine.
Just thought this might help.
Newbie
Message 54 of 54
I have switched off smart setup and i still cannot see the NAS from the PS3. Is anyone still having the same problems? Anything else i can try? Any help appreciated, otherwise I will have to revert to my sky router.
