Message 31 of 54
Re: Home Hub 4 and DLNA
mellycoop,
"I have been told by Tech guys at BT that Hub4 is NOT DLNA compatible" - That seems at odds to what the BT Mod said - http://community.bt.com/t5/Other-BB-Queries/Home-Hub-4-and-DLNA/m-p/937572#M58544 earlier in this thread. Somethings afoot one way or t'other.
 "people need to email BT for the matter to get noticed" - Is there a link to email specifically? or just the usual tech support link?
It does seem odd that some folk seem to get it working OK, others (like myself) partially/mostly successful, and some people can't get it going at all. It would be nice to find the reasons why people experiences are so different for the same hub.
Message 32 of 54
I was having some issues but managed to resolve them by manually redoing the network settings on my PS3.
Only thing that looks like it changed was the device name which was defaulted to PS3(MAC address) before and PS3 afterwards. Worth a try.
Message 33 of 54
Scratch that. Same setup won't play ball today. Nothing at all has changed, ps3 is now unable to see the server.
Message 34 of 54
Hi. I spoke to BT today and asked to return the Home Hub 4.0. I explained the issue, but to be fair I'm not sure the poor girl understood what I was talking about and I can't say that I blame her!
Anyway, I was told a return would be possible which I am happy with and I'm going to stick with the Home Hub 3.0. I might even just buy that Buffalo 5ghz add-on thing for it instead.
Si
Message 35 of 54
Does the HH3 definitely work with DLNA as BT have offered me one of these to try instead of the HH4?
Message 36 of 54
It should work. take it and try. Don't send HH4 back until you are happy.
Message 37 of 54
I have reset all my TVs and Blu Ray back to factory settings and then re-connected to BT internet but still doesn't work. Maybe DeanM could do a bit more research on this and give us another solution.
Message 38 of 54
Hmm, my LG Blu-ray player won't connect via wifi now - always used to with HH2, no errors no need to do ANY setting up, it just connected! Methink we're going back to HH3??
Message 39 of 54
If you are connecting by wireless you will need to enter the wireless key found on the Homehub label into the Blu ray player other wise it won't connect to the homehub
Message 40 of 54
Hmm, I think we are slightly beyond such simple errors!! So no star for you.
My Tv is wired and the Blu-ray is wireless, they both have problems connecting. The blu-ray sometimes connects to the hub but not beyond . . . work in progress but it is definitely the HH4 as all these bits of kit worked seamlessly with HH2. I sent my HH2 back to be recycled . . . mistake I think . . . will BT send me a HH3?? Has anyone else been successful in getting a HH3 sent out as a replacement?
