Myford
Message 11 of 19
Re: Home Hub 4
Hi
This is most odd. The "snip" I sent did not show the whole screen. This one shows a series of vertical lines at the top, under the horizontal menu. Left clicking on these lines brought up the page that Maggie06 was referring to. That is all I can find at the moment! I will click on the sync button and see what happens!
Myford
Message 12 of 19
Re: Home Hub 4
Hi
Well, I can "see" the 5Gb network but there is no title ie You guess. It is obviously the 5Gb because it shows Channel 40 and Security as WPA2 only. So yes, I can now change the 5Gb SSID and Key but all by guesswork.
Not very professional?
John
pottyperson
Distinguished Guru
Distinguished Guru
Message 13 of 19
Re: Home Hub 4
Chances are you're using an ad blocker. If you click its icon you should be able to disable it for the page, or preferably the whole hub site. (If your blocker doesn't have those options you should still be able to turn it off temporarily.)
As you've found, the buttons still work but require a bit of guesswork with the blocker on!
Maggie06
Message 14 of 19
Re: Home Hub 4
Hi John
So glad it is now sorted sorry did not explain myself more clearly
Maggie
pottyperson
Distinguished Guru
Distinguished Guru
Message 15 of 19
Re: Home Hub 4
You explained it very clearly, but if you can't see the buttons ...
Maggie06
Message 16 of 19
Re: Home Hub 4
Hi
Sorry I assume all could see the buttons as mine has been very clear
Just made an ass of myself eh?
Maggie
pottyperson
Distinguished Guru
Distinguished Guru
Message 17 of 19
Re: Home Hub 4
The majority of people would have been able to see exactly what you meant; it just so happens that the original poster seems to have an add-on that has an unexpected side-effect. You were being very helpful, not making an ass of yourself.
Myford
Message 18 of 19
Re: Home Hub 4
Hi potyperson et al
You have "hit the nail on the head". I use Firefox and have Adblock Plus due to being bombarded with adverts in Google Mail. I stopped it from protecting this site and there were the correct headings! What a relief. So I must apologise for the unprofessional statement. It was ME. Ah well, all's well that ends well Smiley Happy
Thanks to all who have contributed to my problem and hope it helps others.
Best Wishes
John
siteguru
Expert
Message 19 of 19
Re: Home Hub 4
I use Chrome with Adblock Plus, so see the same issue. Disabling it for the HH interface makes the links properly-styled. 🙂
I would never have thought about ABP affecting the HH page styles!
Ian
http://www.siteguru.co.uk/be/ADSL2PlusForDummies.pdf - Having ADSL issues? Then read this PDF
Please don't click the star beside my name - too many stars makes you look like a swot!
