william347
Message 1 of 4
Home Hub 5 Firmware Version
The firmware details on my HomeHub is -
BT Home Hub 5 (Type B) | Software version v0.07.06.01239-BT  | Last updated 4/3/2017
Is this the latest version and if not can it be manually updated ?
Thanks for any help.
3 REPLIES 3
licquorice
Message 2 of 4
Re: Home Hub 5 Firmware Version
No idea if it is the latest, but as you can't update it manually the question is academic.
smf22
Recognised Expert
Message 3 of 4
Agree with @licquorice, but as far as versions reported on this forum it seems to be the latest. Versions from old to new that I'm aware of are:
v0.07.01.0235-BT
v0.07.03.0814-BT
v0.07.05.0A13-BT
v0.07.06.09028-BT
v0.07.06.01239-BT
You'll note the version number of the 'latest' firmware is actually lower than the previous i.e., 09028 is a higher number than 01239. Users have seen Hub firmware change from 09028-BT to 01239-BT with the suggestion in New HH5B update, version number lower than the old... that there was a 'typo' in the version number and it should of been 10239-BT.
Regards
william347
Message 4 of 4
Thanks for the reply , i wondered about the number , didn't find previous post you provided
