WaltJabsco
Message 21 of 39
Re: Home Hub 5 and Apple Airport Extreme/Time Capsule
It states "Error reading configuration"
licquorice
Message 22 of 39
How are you connecting to the AE once you have changed its address? You need to enter 192.168.1.10 in your browser address bar.
WaltJabsco
Message 23 of 39
Via Airport Utility on my MacBook Pro.
When I enter those numbers in the browser, I get my wireless speaker support page.
stevebrass
Expert
Message 24 of 39
I have run an AirPort Express through a HH 5. I connected AE via its wan port to an Ethernet port on the HH 5
Using airport utility under Internet options I set the AE to connect using DHCP. You may get a double NAT advisory but I ignored this.
Everything worked well. I did switch off the HH5 wifi.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
licquorice
Message 25 of 39
Ok, I guess that address is being used by something elase. In which case, give it another address that isn't being used. Or, I guess, connect as Stevebrass has done.
WaltJabsco
Message 26 of 39
How would I give it another address?
Stevebrass, when I open Airport Utility nothing happens - what might I be doing wrong?
licquorice
Message 27 of 39
The same way you gave it an address of 192.168.1.10, just use a different address that is not being used on your network.
WaltJabsco
Message 28 of 39
How do I choose an address though? Can I just make the numbers up?
PS I'm not technically minded so this is a bit foreign to me.
licquorice
Message 29 of 39
No, it needs to be 192.168.1.xxx where xxx is not being used on your network.
How is everything connected at the moment and why do you need to add a HH5 to the network?
stevebrass
Expert
Message 30 of 39
You say nothing happens - it doesn't  show the TC then?
How are you using the TC at the moment?
