Deathtrap3000
Recognised Expert
Message 11 of 15
Re: Home Hub 5 engineer visit still required?
Cab work means work at the cab. No exchange work required. They dont use the iplate. Its a ssfp. If you look on an auction site for vdsl faceplate or similar.
Deathtrap3000
Recognised Expert
Message 12 of 15
@gg30340 wrote:
The official answer is no because the master socket is BT property and you are not allowed to tamper with it. Even if you do change it you will still get an engineer visit. They won't connect it up otherwise.
All they do in most cases is fit a faceplate over the NTE. This is most certainly allowed to be done by customer.
Liam548
Message 13 of 15
Ssfp? What's the best faceplate available?
Ectophile
Distinguished Guru
Message 14 of 15
The Openreach engineer will normally replace the whole master socket as part of the install, and will want to test the line to check that it is working.  Unless you have some desperate reason not to let the engineer into your home, it's easier to let them do all the work, at Openreach's expense.
EvilShubunkin
Message 15 of 15
Probably depends on the master socket - install last year and engineer replaced the faceplate only and synchs at top end of estimates (and way above estimates before the checker changed how it displays its results).
