Message 11 of 13
Re: Home Hub 5 problems with other router connected.
@hcharge wrote:
Doesn't that affect using YouView for certain channels? No idea with OR modem and your router, but no with VDSL modem/router And would I have to buy an OpenReach modem? Yes
Message 12 of 13
Ahhhh OK! That makes sense then haha, OK cool, for now I'll change the SSID and set it to an opposite channel, gah! Can it have just the 5GHz radio on and not the 2.4GHz?
Distinguished Guru
Message 13 of 13
Sorry, I don't know, I just turned both on.
However I did see a suggestion it was just the 2.4GHz that needed to be on - so...?
If not, I'll try again 🙂
