Lugton
Message 1 of 5
Home Hub 5 ( type b ) connectivity with Sky Q
Hi, I am running BT Infinity and Sky Q. The TV on the main Q box is 100% ok. On the TV connected to the mini box the connectivity drops for a few seconds intermittently with the message - you cannot watch TV at the moment due to a connectivity issue. After a few seconds the TV picture resumes.
I have tried stopping the 5ghz syncing and also changed the 5ghz SSID but it makes no difference.
Any suggestions?
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Home Hub 5 ( type b ) connectivity with Sky Q
Avoid using wireless if possible, as its easily overloaded. and likely to drop the connection if there is interference.
Try broadband extenders instead.
http://www.shop.bt.com/mini-sites/connected-home/broadband-extenders
Lugton
Message 3 of 5
Thanks for the reply. I doubt if extenders work, Sky Q uses wifi to connect from the main box to the mini box.
bunyarra
Message 4 of 5
Nope - the mini boxes also support wired connections
Lugton
Message 5 of 5
Thanks for pointing out that mini boxes can have wired connections.
